| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Rail users require degree of curve versus radius within the Geometry>Define Horizontal Curve>Design Calculators command, how can I change this input?
The Design Calculators command coverts the degree of curve to radius and then apply to the Cant Calculator. As a test; d 1, a 1 degree curve has a radius of 5729.651, key-in d 1 at Radius and then select the tab key, the degree is converted to radius.
