| Version(s): | 08.11.09+ |
| Area: | Survey |
Problem:
Feature Codes that contain an alpha code (such as STEP) are being read as "Start EP" instead of recognizing that STEP is the feature code.
Beginning in version 08.11.07.674 a configuration variable was added to force a space between feature code and linking code:
CIVIL_SURVEY_LINK_CODE_IS_SPACE_SEPARATED=1
If this variable is set, a space is required between the Linking Code and the Feature so the linking code is recognized and will not become part of the feature. Example, consider the case of STEP:
Linking codes can be part of a feature with this variable set.
