| Version(s): | 08.11.09.722+ |
| Area: | Survey |
Question:
Is it possible to control how curves containing multiple points are drawn in OpenRoads Survey?
Is there a difference in how curves were drawn in SS2 Data Acquisition and in SS3 OpenRoads Survey?
Answer:
There is a configuration variable that controls how curves are generated:
CIVIL_SURVEY_SPLINE_TYPE
The two most common values for this variable are:
CIVIL_SURVEY_SPLINE_TYPE = 1 (InRoadsCubic - This is used by default if the variable is not defined. This method generates b-spline curves using the same method InRoads survey used.)
CIVIL_SURVEY_SPLINE_TYPE = 2 (Curve - This is the method used by default in SS2 Data Acquisition. If a user is seeing curves drawn differently in data brought forward from SS2, they will set the variable to this value.)
The following image shows what a curve might look like that is brought forward from SS2 Data Acquisition:
Default with no variable (CIVIL_SURVEY_SPLINE_TYPE = 1)
The following is a list of other values that can also be used. These are primarily the same options used by the MicroStation "Create Curves" command:
0 = BiArc
3 = Points
4 = Poles
5 = CatmullRom
6 = ConicCurves
7 = LeastSquares
8 = LeastSquaresTol
