| Version(s): | 08.11.09+ |
| Area: | Survey |
Question:
Why am I getting the "Select Linked Feature Definition Style File" even though I have already set the XML/XIN/PSS path in the CIVIL_SURVEY_STYLEFILE_FILE configuration variable.
Answer:
The correct configuration variable name is "CIVIL_SURVEY_STYLEFILE".
In previous versions of GEOPAK/InRoads/MX, the readme file incorrectly listed the configuration variable as "CIVIL_SURVEY_STYLEFILE_FILE". This is a typo, and the correct variable is:
