Using linear feature templates (TMPL code) in Survey
Version(s):08.11.09+
Area: Survey
Question:
How use the linear feature templates (TMPL) while collecting survey data?
Answer:
Survey linear feature templates and the TMPL control code have been enhanced to allow multiple linear features to be collected at once.
Start a new feature like normal then append TMPL Feature_Code Horizontal_Offset Vertical_Offset , etc.
Example: Start a line on the GUT and automatically collect Top of Curb (TC), Back of Curb (BC) and EP.
 GUT ST TMPL TC 0.1 0.5 BC 0.5 .05 EP -2.0 0.1
 GUT
 GUT
 GUT PC
 GUT
 GUT PT
 GUT
 GUT END
Or locate the other linear features with a field shot to define the Horizontal and Vertical offset.
 GUT ST TMPL
 TC ST
 BC ST
 EP ST
 GUT
 GUT
 GUT PC
 GUT
 GUT PT
 GUT
 GUT END
