| Product(s): | InRoads |
| Version(s): | 08.11.07+, 08.11.09+ |
| Area: | Tools |
Question:
Where is the Variable Manager command?
Answer:
The Variable Manager is an Application Add-In. To access this command, you must first add it by going to Tools>Application Add-Ins.
Place an "X" in the check box next to "Variable Manager Add-In". Click OK.
Now the Variable Manager is accessible by going to Tools>Variable Manager.
