| Product(s): | InRoads |
| Version(s): | 08.11.07.615 |
| Area: | Geometry |
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
How can I free an alignment and/or cogo buffer that has been locked by another user if that user is no longer available?
Answer:
In the InRoads Explorer window, right-click on the geometry project name and select "Details".
In the Access Control Details list, locate and highlight the locked alignment/cogo buffer. You can hold down the <Ctrl> key and select "Free" to free an alignment/cogo buffer that may be locked by another user.
