| Version(s): | 08.11.09+ |
| Area: | Analysis & Reporting |
Question:
I have created a Point Feature Station Offset Elevation Report, however the elevations are all blank. Why is this?
Answer:
This tool can be used in 2D or 3D views or models; however, If data in a 2D model or view is used, the elevation field is left blank.
