| Version(s): | 08.11.09+ |
| Area: | Cross Sections |
Question:
There are several components displayed in my cross section that I do not want considered in End Area Volumes. Is there a way that I can exclude them from the calculations?
Answer:
In the End-Area Volumes tool, go to Classifications. Select the component you wish to exclude and change its classification to "Ignore".
