| Version(s): | 08.11.09+ |
| Area: | Analysis & Reporting |
Question:
Where are the symbology, precision, and settings defined for the Inverse Points tool?
Answer:
The active MicroStation symbology, text settings, and drawing scales are used for this tool. The direction values use the Design File Settings > Angle Readout settings for format, accuracy, and direction mode. The number of decimal places for the distance is determined by the Design File Settings > Working Units > Linear Units Accuracy value. The layout and content of the annotation is not user-definable.
