| Version(s): | 08.11.09+ |
| Area: | Vertical Geometry |
Question:
What is the difference between the Profile By Slope From Element tool and the Profile By Variable Slope From Element tool?
Answer:
These two commands differ only in the fact that you have additional options in the Profile By Variable Slope From Element tool. Specifically, you can define a range instead of the entire element, and there are multiple methods of slope style rather than fixed slope alone.
In the Profile By Variable Slope From Element tool, the options for slope styles are:
