Product(s): | InRoads, MX, GEOPAK |
Version(s): | 08.11.09+ |
Area: | Survey |
Question:
When collecting data in the field, I typed in the wrong point number on my backsight. How do I change it to the correct point?
Answer:
There are two ways to change the backsight point for a setup:
1. In the Survey tab of the Project Explorer, highlight “Setups” and view the details:
Click in the Backsight column for the setup you want to edit and type in the new point number:
2. Or highlight the setup you want to edit and right-click and select Edit Selected Items>Backsight and type in the new backsight name:
