| Product(s): | Bentley GEOPAK Civil Engineering Suite | ||
| Area: | Road > Cross Sections > Reports | ||
| Subarea: | Export To HECRAS | ||
| Original Author: | Beebe Ray, Bentley Technical Support Group | ||
Trying to export cross sections to HECRAS and when I run the tool nothing gets processed.
Make sure there are only cross sections in the DGN file from the one chain you would like to send to HECRAS. If there are cross sections from other chains you will need to move them into their own design file.
