| Product(s): | InRoads |
| Version(s): | 08.11.07+ |
| Area: | Tools |
Question:
How do I strip InRoads data from an element?
Answer:
The Remove User Data command removes user data from graphic elements in the design file. This command searches for InRoads user data from selected graphic elements and removes all attributes associated with the element(s). Remove User Data is an Application Add-In. Select Tools>Application Add-Ins and select Remove User Data. The tool can then be found in Tools>Remove User Data.
A video demonstrating this tool can be found at the link below:
communities.bentley.com/.../19914.video-remove-user-data
