| Version(s): | 08.11.09+ |
| Area: | Vertical Geometry |
Question:
If you have used the Profile Intersection Point tool to determine the location of a point in profile, will the profile update if the point of intersection is revised?
Answer:
Yes, as long as you have snapped to the point of intersection when you created the profile, it will be adjusted to match the new point of intersection. By snapping to the point of intersection, you communicate your design intent, and the profile is ruled to the point of intersection.
