| Product(s): | InRoads | ||
| Area: | General | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
I am using the same preference file as the other people in the office, but InRoads will not display the tangent sections of an alignment with Northing/Easting. I have double checked all of my settings and they seem to be the same as everyone else’s, but mine displays as degrees, minutes and seconds. I am using a remote desktop connection, but didn't think that would have anything to do with it.
From the menu bar select Settings>Design File>Angle Readout. In the middle of the dialog box, Direction Mode select Bearing and then Ok. This should resolve your issue.
