| Product(s): | InRoads | ||
| Version(s): | 08.11.09.722 | ||
| Area: | General | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
In InRoads Survey, there used to be an "InRoads Site" selection under "Application Add-ins" so the user could access some functions of InRoads Site while working in InRoads Survey. That selection is no longer listed under Application Add-ins. Was this discontinued and if so, what was the last version to have it?
The Product Add-Ins functionality is not available after SELECTseries 2; this functionality is available in 08.11.07.615 which is the latest version of SELECTseries 2. Within SELECTseries 3 and SELECTseries 4, you can no longer access multiple products or Add-Ins, you must launch the product for which you intend to work.
