| Product(s): | InRoads | ||
| Version(s): | 08.11.09.721 | ||
| Area: | General | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
I've generated cross sections in the latest release of PowerCivil SS3. However, all of the vertical 3D elements are not shown! Any setting I've been missing?
When elements are not displayed, one of the first things to check is the Feature Definition. Make sure a feature definition has been assigned and check the settings. Also, ensure the assigned levels are on for that element and that the element’s elevations are correction and fall within the cross section elevation range.
