| Product(s): | InRoads | ||
| Environment: | |||
| Area: | Reports | ||
| Subarea: | |||
This report format is similar to the delivered Clearance.xsl report that is delivered with InRoads. You must create clearance points for this report by selecting Tools > XML Reports > Clearance. You must include at least one horizontal alignment or feature on the General leaf in the From fields. You must also include at least one feature from the Features leaf.
Unzip the file Clearance Report for Features and place it in the XML Data directory for the version of the product installed. This report may be placed in the Custom folder or the Clearance folder.
(ex for XM - C:\Program Files\Bentley\InRoads Group V8.9\XML Data\Custom)
(ex for V8i SS2 - C:\Program Files (x86)\Bentley\InRoads Group V8.11\XML Data\en\Custom)
