| Product(s): | Bentley GEOPAK Civil Engineering Suite | ||
| Version(s): | 08.11.07 + | ||
| Area: | Drainage | ||
| Subarea: | Display 3D | ||
| Original Author: | Beebe Ray, Bentley Technical Support Group | ||
How do I display my drainage links and drainage nodes in 3D
In a 3D Design file, open your drainage project and select the Display 3D tool from the Drainage Menu>Utilities pulldown. This tool will draw your links and nodes in 3D. There is some setup for the nodes that needs to be done first as shown below.
