| Version(s): | 08.11.09+ |
| Area: | Subsurface Utility Engineering |
Question:
Is it possible to convert a SUE model back to a terrain model?
Answer:
In the SS4 release, there is a 3D line string coincident with every pipe. In the SS3 versions, this line string is suppressed.
From the 3D view, the user is able to select these line strings and create a terrain model using the Create from Elements tool.
