| Product(s): | GEOPAK Drainage | ||
| Version(s): | N/A | ||
| Area: | Import Drainage Project | ||
| Subarea: | N/A | ||
Merger Two Geopak Drainage Projects into one
This video demonstrates how to create merge two drainage projects into one so that you can have access to networks, nodes, and links from both.
Recorded in 1024 x 768 resolution.
