| Version(s): | 08.11.09.493+ |
| Area: | Terrain Model |
| Original Author: | Beebe Ray, Bentley Technical Support Group |
Problem:
What is a Soft Break Line?
A soft Break Line is a break line but if it happens to cross another break line then is will be ignored so as to not affect the triangulation, a graphic break line is a soft break line that will not be stored in the terrain model, and a break line is what it has always been, a line where triangles will not cross over.
