| Version(s): | 08.11.09+ |
| Area: | Survey |
This video walks through an example of using the "Use VBA Macros" option in the Open Roads Survey tools. Survey delivers an example ""SmartObjects.mvba" file with the Bentley Civil workspaces. The folder that contains this macro is called out in the "MS_VBASEARCHDIRECTORIES" variable in the workspace. To have the MVBA project automatically load, add the path to the MVBA to the MS_VBAAUTOLOADPROJECTS configuration variable,for example: MS_VBAAUTOLOADPROJECTS > $(_USTN_PROJECTDATA)/prefs/SmartObjects
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
