| Version(s): | 08.11.09+ |
| Area: | Corridor Modeling |
Question:
Can the templates in Descartes be used in OpenRoads?
Answer:
Descartes template cannot be used directly in OpenRoads. However, the templates can be used to make the shape. If you create a mesh out of the shape, the mesh object can be imported to OpenRoads as a surface feature.
