| Product(s): | InRoads |
| Version(s): | 08.11.07+ |
| Area: | Geometry |
Question:
How do I change the curve definition for an existing horizontal or vertical alignment?
Answer:
In the InRoads Explorer, perform a long right-click on the alignment name. This will bring up a menu. At the bottom of the menu list, you will see the options to change the curve definition for that alignment.
