| Applies To | | |
| Product(s): | GEOPAK Civil Engineering Suite, PowerGEOPAK | |
| Version(s): | Select Series 2 08.11.07.615 | |
| Environment: | N/A | |
| Area: | Existing Ground Profile | |
| Subarea: | Store Existing Surface into COGO | |
| Original Author: | Bentley Technical Support Group | |
There have been times when a user has not been able to use the Ground Profile Tool accessed from Project Manager to store an existing ground profile into COGO. In these situations it may be helpful to use the Draw Profile Tool to accomplish the same task. You can draw the ground profile using the Draw Profile Tool and then you will have the option to Store that profile into COGO after it is drawn. The following video will demonstrate.
Support Video Clip
