| Product(s): | ProjectWise Caching Server | ||
| Area: | Explorer | ||
PID 50206: Last Error [58007] Error deleting a folder. Folder has documents. A folder that has documents can not be removed. Remove documents first.
User was unable to delete a folder that contained more than one version of a file.
Go into Tools - Options, then click on the settings tab and expand document list, make sure "show all versions" is enabled. Once we did this and were able to see our versions, we were able to delete the folder that contains files with several versions.
