| Product(s): | ProjectWise V8i | ||
| Version(s): | 08.11.05.37 | ||
| Area: | File Transfer Svr-Caching Svr | ||
When running the Delta File Transfer Benchmark tool, the times for check in are faster when using DFT, but check out is faster when not using DFT
DFT is most useful when bandwith and LAN latency is an issue, sometimes its faster to transmit the entire file rather than computing the differences.
The check in times are generally faster because it always has a copy on both sides (client and server) to compare and will only transmit the changes.
A checkout usually has to transmit the entire file depending on if the client already has a copy of the file.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" sectioXn. THANK YOU!
