| Product(s): | InRoads | ||
| Area: | Drafting | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Within the Plan and Profile Generator, I would like for my profiles to read Right to Left and not Left to Right as they currently read.
Create a preference within Evaluation>Profile>Create Profile. On the General leaf, Direction, you can select the direction for which your profile will read and save preference.
Within Plan and Profile Generator, select the Profile Controls tab and at Profile Preference, select the newly created preference that defines your desired reading direction.
