| Product(s): | PROJECTWISE CACHING SERVER | ||
| Version(s): | 08.11.XX.XX | ||
Error 58064 when creating a datasource.
Customer is doing an upgrade to V8i. He is at the point of creating the datasource and it is failing with error 58064
Also in the log the error message reads: ERROR [0x00002404] pwise.dms - Error 20064 "Invalid password" reported at func: dmsDmmUserVerifyAndUpdatePasswd line: 1454
Had the user use a different admin account to create the datasource, as it was possible the client did not give him the correct password for the original admin account. Using a different admin account with the correct password solved the problem.
