| Product(s): | ProjectWise Caching Server | ||
| Version(s): | 08.11.XX.XX | ||
Error when creating documents in ProjectWise V8i
No new documents can be created in PW 8.11.5.16 either in PWE or through Web Parts. The error in PWC is: "Last Error [58117]. Field value must be unique." The error in Web Parts is:
"Server Error in '/' Application.
Operation is not valid due to the current state of the object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.InvalidOperationException: Operation is not valid due to the current state of the object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[InvalidOperationException: Operation is not valid due to the current state of the object.]
Bentley.EC.Presentation.View.ValueListsModifier.CreateQueryBackedValueListAttribute(RepositoryConnection connection, ECQuery valueListQuery, String valuePropertyName, String displayStringPropertyName, Type type) +833
Bentley.EC.Presentation.View.ValueListsModifier.SetValueList(RepositoryConnection connection, FieldDisplayInfo fieldInfo, ECQuery instancesQuery) +222
Bentley.ECOM.ProjectWiseProvider.DocumentViewRetriever.AddDocumentPropertiesViewAttribGuiFields(ECQuery documentQuery, RepositoryConnection connection, List`1 fieldDisplayInfos, IECSchema staticSchema, IECSchema dynamicSchema, Boolean readOnly, Boolean finalStatus, ECQuery environmentIdQuery, String contextNodeId) +2902
Bentley.ECOM.ProjectWiseProvider.DocumentViewRetriever.AddNewDocumentPropertiesViewAttribGuiFields(ECQuery documentQuery, RepositoryConnection connection, ECTypedKey parentKey, List`1 fieldDisplayInfos, IECSchema staticSchema, IECSchema dynamicSchema, Boolean readOnly) +234
Bentley.ECOM.ProjectWiseProvider.DocumentViewRetriever.GetNewDocumentView(RepositoryConnection connection, NavNode navNode, IExtendedParameters contextMap) +2665
Bentley.ECOM.ProjectWiseProvider.DocumentViewRetriever.GetNewInstanceView(ECView ecView, NavNode navNode) +82
Bentley.ECOM.ProjectWiseProvider.BaseViewRetriever.GetView(ECView ecView, NavNode navNode, String[] classIdsIn, String[] classIdsEx) +252
Bentley.ECOM.ProjectWiseProvider.DocumentViewRetriever.GetView(ECView ecView, NavNode navNode, String[] classIdsIn, String[] classIdsEx) +139
Bentley.ECOM.ProjectWiseProvider.BaseViewRetriever.GetView(ECView ecView, NavNode navNode) +245
Bentley.ECOM.ProjectWiseProvider.ProjectWiseViewProvider.GetView(RepositoryConnection connection, ECView ecView, NavNode navNode, String[] requiredFields, IExtendedParameters contextMap) +156
Bentley.EC.Presentation.View.ViewServiceInProcess.GetView(RepositoryConnection connection, NavNode navNode, String[] requiredFields, IExtendedParameters extendedParameters) +161
Bentley.EC.Web.UI.WebControls.WebParts.Content.LoadContentGroups() +715
Bentley.EC.Web.UI.WebControls.WebParts.Content.EnsureContentGroups() +15
Bentley.EC.Web.UI.WebControls.WebParts.Content.CreateChildControls() +14
System.Web.UI.Control.EnsureChildControls() +87
System.Web.UI.Control.PreRenderRecursiveInternal() +50
System.Web.UI.WebControls.WebParts.WebPart.PreRenderRecursiveInternal() +62
System.Web.UI.Control.PreRenderRecursiveInternal() +170
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2041
Version Information: Microsoft .NET Framework Version:2.0.50727.1433; ASP.NET Version:2.0.50727.1433 "
Check the environment attributes of the folder that documents cannot be created in. The issue can be caused by environment attributes Value lists of wrong type. For instance, there may be an environment attribute Attr1 of type Date and if it has a fixed Value list consisting of text strings Obsolete|Valid - that will cause the error mentioned above. Solution is to make sure that all of the Value lists for environment attributes are adequate. The value lists are stored in the table DMS_EVAL of the database.
