| Product(s): | ProjectWise Caching Server | ||
| Version(s): | 08.11.5.37 | ||
Workspace data does not load up. When starting MicroStation without ProjectWise, MSTN starts correctly. When starting from within PW Explorer, MicroStation fails to use proper Workspace.
The problem seems to be, that PW was not able to get the PROJECTDATA path correctly, as it was defined with the normal slash in the user UCF file:
P:\workspace\project\
When we have changed the sign to backslash at the begining:
P:\workspace\project/
it started to work fine.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
