| Product(s): | ProjectWise Caching Server | ||
| Version(s): | 08.09.04.xx | ||
| Area: | Projects | ||
DDE Server Window: ustation.exe - ....\bin\v8\mcm.dll, error 127.
Uninstalled ProjectWise Explorer, rebooted. Tested to ensure Microstation would work without errors. Installed ProjectWise explorer and ensured it was integrated with Microstation. Tried a repair before the uninstall but the repair did not fix the problem.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
