| Product(s): | ProjectWise Caching Server | ||
| Version(s): | 08.09.04.xx | ||
| Area: | Projects | ||
Losing history of changes while referencing a model in a different version.
The problem is that versioning needs to be done within a set. In this set you would grab the sheet and all reference files.
More information on how to do this can be found in ProjectWise Explorer |help |search for versions |and select “Creating New Versions Of Documents”, then select “To create a new version of a master document and its references”.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
