| Product(s): | ProjectWise Caching Server | ||
| Version(s): | 08.09.04.xx | ||
| Area: | PROJECTS | ||
Manage Views disappearing in Projects. User has created customized views, and has noticed that for some projects, her views are not available to her.
The problem was related to Resource inheritance in ProjectWise Explorer.
To Reproduce:
1. Open ProjectWise Explorer
2. Right click on a Project | Properties | Resources
3. In the “Resources Type:” drop down box select “View”
4. Compare the setting next to the “Inherited From:” area on the project that displays the views correctly to the project that does not display the views correctly.
5. Make the appropriate changes (add, remove, Inherit) to the appropriate project to correct the problem.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
