| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Audit Trail | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
User recently upgraded from 08.11.07.107 to 08.11.11.574. His users started complaining that the audit trail was no longer logging document actions such as check-in, checkout, modify, create, etc. Checked his audit trail settings and all the check-in \ checkout \ create \ modify etc.. settings were unchecked.
This is a known issue when upgrading from a version that used the old audit trail settings to a newer version that uses the more robust audit trail settings.
