Workflow Rules Engine Listings not Populating
Product(s):ProjectWise Explorer Client
Version(s):08.11.11.574
Environment: Windows 7 64 bit
Area: BS1192 Rules Engine
Original Author:Bill Kenney, Bentley Technical Support Group
Problem Description
When I configure and import my Workflow Rules Engine .xlsx template, I still do not get my custom > Right click > Change State listings
Steps to Resolve
In the Workflow Rules Engine template, on the "Operations Type" tab, make sure you replace the default "Rules Engine Workflow" in Row 2 Column H with the name of your custom workflow in The "Rules" tab in Column A. You should then get the proper listing of your custom "Change State" names.
