| Product(s): | ProjectWise Client V8i | ||
| Version(s): | 08.11.07.443 | ||
| Area: | Explorer | ||
Cannot move document versions.--Moving file in PW from one folder to another does not allow to move versions.
Last Error [ 50190 ]
Cannot transfer documents.
One or more documents have versions. You are not allowed to move document having versions.
Toggle this setting in the Database Properties: "Documents with versions can be moved"
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" sectioXn. THANK YOU!
