| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.111 | ||
| Area: | Integration - Revit | ||
| Subarea: | GUI | ||
| Original Author: | Raul Guerrero, Bentley Technical Support Group |
Revit Integration - AutoDesk Revit has stopped working. An unrecoverable
error has occurred.
Product: ProjectWise Client V8i
Version: 08.11.11.111
Area: Revit Integration, Problem ID#: 88488, PROBLEMSOLVING
Note: If you disable Integration Revit works fine.
The problem turned out to be an access violation. We checked for any anti-virus or other
protection software and turned out the user had DeviceLock. This was causing issues with Revit integration by blocking the creation of the R drive. TSG's recommendation is to remove DeviceLock. Once Devicelock was
removed from one system, the PW/Revit integration worked fine.
The user had a workaround that involved modifying the registry.
