| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.123 | ||
| Area: | Integration - Revit | ||
| Subarea: | Open / Close / Save As | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
Opening Revit central file from ProjectWise, when Revit opens, user gets
PW log on message, followed by "Copied Central Model" Revit message.
After making changes and saving to central, get Revit error "File not saved"
Product: ProjectWise Client V8i
Version: 08.11.11.123
Area: Idesktop Integration, Problem ID#: 87972, PROBLEMSOLVING
See Also: Revit
User was not using the correct program association. He had a user association instead of the valid global association Revit.Document.PW.
