| Version(s): | 08.11.09+ |
| Area: | General Geometry |
| Original Author: | Jason Walsh, Bentley Technical Support Group |
Problem:
The graphic manipulators are not showing up when civil elements are selected.
The reason for this is that the Disable Handles toggle on the Element Selection panel has been selected.
Un-select the Disable Handles toggle on the Element Selection panel and the graphic manipulators for the civil elements will be visible.
