Product(s): | ProjectWise Explorer Client | ||
Version(s): | 08.11.11.590 | ||
Area: | Search | ||
Original Author: | Dana Guthrie, Bentley Technical Support Group |
How do I see what files a user has checked out, copied out, or exported without being on the users computer.
I need to find out what files some of my users have checked out, copied out, or exported and on which computer the files are located.
On the General page find the "Out to" pull down and choose the users login name.
Make sure you are searching the entire datasource.
Click apply and okay. Make sure you are using the view you created to see the results
Go to Tools, Local Document Organizer.
There should be three pull down menu options; Datasource, Node, and User
Choose the Node (computer name) the user uses, and the users login name. The list of files the user has out on the machine you choose will appear in the results pain.
