| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Search | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
Last Error [-1] The view contains invalid column '{name}.
User has exported a project from a test environment that included saved searches, and has imported it into a new datasource. When he clicks on his saved searches or the view he gets the error.
We compared the global views between the two datasources, and they were not the same.
Once we made them the same and assigned the correct environment to the view, the searches and views started working correctly.
