| | Product(s): | ProjectWise Explorer Client | |
| | Version(s): | 08.11.11.111 | |
| | Area: | Views | |
| | Original Author: | Darius Perminas, Bentley Technical Support Group | |
User creates new view in PW project and the view is not visible for selection.
- When in project, right-click on project and open properties;
- Select 'Resources' tab;
- From Resource Type pick 'View';
- Make sure you have the right configuration here - if there are concrete views selected, then newly created views won't be visible. You can add particular view by clicking on 'Add...'. If you do not want to restrict the views in this project, click 'Inherit' and all the views created will be visible for selection.
