| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Integration / Caching /Gateway | ||
| Subarea: | Installation | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
After following this procedure, when logged on to a Windows machine as a domain account that exists as a user in ProjectWise, the user will automatically be logged into the ProjectWise datasource in ProjectWise Explorer or Administrator
1. On the ProjectWise Integration Server, browse to the PW installation directory
c:\program files (x86)\bentley\projectwise\bin (Pre-SS4 versions)
c:\program files\bentley\projectwise\bin (SS4 + higher)
2. Open dmsknrl.cfg in notepad
3. At the bottom of the file in the appropriate datasource section add the line "SSO=1"
Example:
[db0]
Description=datasource
Type=Microsoft SQL Server
InterfaceType=ODBC
Name=servername
DBUserName=sa
DBUsrPwdDecrypt=4
DBUserPassword=#UCEEM7s54ZRWqZt3RpaXREsuskgcxxv9+bzLUgGBqq5Butrg
SSO=1
