| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Integration / Caching /Gateway | ||
| Subarea: | Installation | ||
| Original Author: | Jacquelene Smiro, Bentley Technical Support Group |
Error 1325 Projectwise is not a valid short file name.
Upgrading Integration Server and receives error 1325 Projectwise is not a valid short file name.
Set up installer logging to see what is preventing install -
http://support.microsoft.com/kb/223300
Msi Logging indicated problem with modifying INDEX_STORAGE_DIR property. Its current value = 'C:\ProgramData\Bentley\pw-index-storage\'. Its new value: 'D:\ProjectWise\Index\Data'.
Redirect registry entries as Index was originally installed on another drive on Production server.
