| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Integration / Caching /Gateway | ||
| Subarea: | Installation | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
Error found in pwadmin.log
pwise.server - Error 241 "ODBC ERROR: 22007: [Microsoft][ODBC SQL Server Driver][SQL Server]Conversion failed when converting date and/or time from character string." reported at func: dsqlOdbc_execDirect line: 1135
User was not running a supported version of SQL Server, 2008 RTM instead of the required SQL 2008 R2
Verify the exact version of SQL server here
Check the readme for the version of ProjectWise you have installed for the supported database versions
