| Product(s): | ProjectWise Integration Server | ||
| Version(s): | 08.11.11.111 | ||
| Area: | Integration / Caching /Gateway | ||
| Subarea: | Licensing | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
Evaluation Only option in Product Activation Wizard and ProjectWise.
I am working on a Test Environment for SS4. I have an Evaluation license, so on the Product Activation Wizard, one of the options is Evaluation Only. If I use the Evaluation License, how long do I have before it times out?
The evaluation term is for 30 days.
If the activation wizard already had a server and activation key specified, and you go back in and change it to eval mode, ProjectWise will still get a the regular license from the SELECTServer.
To get it back to an Evaluation license, you will need to remove the server name and activation code first, click apply, and okay, and close the license tool. Relaunch the license tool reconnect to your server and input the activation key, then go back and choose the eval mode. Additionally you will need to stop and restart the Projectwise services. Check the event application log to see that the ProjectWise Integration service is running and has 29 days left.
