Does InRoads/MX/GEOPAK SS4 run on Windows 10?
Version(s):08.11.09+
Area: Basic Settings
Question:
Answer:
The civil products have not been certified and are not supported on Windows 10.  Version 08.11.09.845 (the latest released version at the time of this posting) is certified on the follow operation systems:
Windows 8 Note: It is highly recommended on the User Access Controls (UAC) be set on the lowest setting. In addition, the InRoads Group V8.11 folder will need to be open for write access.
Vista/Windows 7 Note: It is highly recommended on Vista and Windows 7 operating systems (32 and 64bit) that the User Access Controls (UAC) be turned off (Vista) or to the lowest setting (Windows 7).
